New position assignment
I am not able to assign a new position to employee. The continue tab is disabled when assigning the new position to the employee.
I ended the previous position, but still not able to perform the activity.
I tried to disable the personnel action configuration in License configuration, but still no luck.
Kindly suggest.
Can you please post a screen shot?
Currently I don’t have the screen shot. But could you suggests any possible solution for the issue.
Can you tell the steps that you are following?
Following are the steps performed:
  1. Created a new job and position.
  2. Tried to assign the same position to the existing employee.
  3. The employee was already assigned with a position.
  4. On the employee form → Action pane → Worker assignment → clicked on new to assign a new position.
  5. But the continue tab is disable. I ended the previous position assigned on employee. But still no luck
Kindly suggest.
How was the original position created - my importing the data by any chance?
I don’t remember. But I think users created it manually.
I would check the configuration of the position, department and the legal entity structure etc. and I would run the Number Sequence Wizard to check nothing is missing.
