Hi everyone… I’ve created a new language using the label wizard. The problem is, when I check the list of languages available in the configuration utility, the newly-added language is not among the choices. Can anyone help me with this???
Hi, Configuration Utility does not know about anything about DIY made label files. Look at the clients install directory “C:\Program Files\Navision\Axapta Client\Bin” There you see a lot of files with file types “ktd” which means Kernel Translation Data. These files are installed by the installer and they contain static texts you need to output without the license for the language. You can edit them with notepad. The configuration utility shows only these languages. br,
