I am mvoing Navsion 5.0 sp1 to a new domain
All windows logins will be different
I have backed up the Navison database and restored onto the new domain under sql 2005
I created a new sql windows login, but it pulls data from the database and adds the old domain user so the windows login does not work.
I created a sql login but this does not work because the user already exists in the Navison .
What is the best way to backup/restore the database without the user info in side.
Can I export the roles and username so I recreate them
Hi David,
What happens is that your SQL has logins and NAV will make references to them in the user table.
Once you move the domain , your windows logins will change (they have different sid) .
What you can do is to update their sid, or re-create them.
With regards to SQL login , you need to delete the existing user from the database(!) and then create the login with same name as before , then create a user in the database with same name as before , then you are good to go.
Gabor
How do I update the Windows SIDs?
If I delete and recreate the database accounts is there anyway to export the users and there roles to a spreadsheet so i can add the roles back in
David,
You can update the SIDs in the database itself , but of course you need to be aware of the new sid per login.
Look for the table Windows Login and Windows access control in the SQL management studio .
If you do the trick of recreating login and db user with same name , then you dont need to worry about roles. Those would work just fine.
g.
When I create the windows login this is what i see
The elliottgroup is the old domain
Are the tables Windows Login and Windows access control in the Navision database
Yup , the tables will be in this case in the database “Eliott Group”.
Note that one thing to have access to the database via SQL , the other is the authorization within the NAV application.
Thus , you can have any SQL/windows login accessing the db , that will not fix things up until you clear the NAV app authorizations .
I guess to aviod the problems, you can just recreate the users then you are starting with a clear sheet.
g.
I could strat with a clean sheet but i have 200 users so would need some way of expoerting the roles if possible so i can enter them back into Nav manually if needed
So do you have a map of old and new sid’s ?
g.
I have a spreadsheet old old and new user logins
