Hi, I have a new document ( Internal Consumption ). This document have header and line. In line is Items . Items have set Item tracking ( SN and LN ) This document don’t have Item Tracking Line option . In can assign Item Tracking Line for a line in this document ? I must modify some Codeunits for Reserv an Item. Theese codeunits is for make a reserv for an item an post this document. This document write in : G/L , Item Ledger Entry, Value Entry. Is possible to add new DATABASE in reserve codeunits ? Is very difficult ?? [:(!] Thanks, IM
Hello Ioan, I have the same problem with you. I hope you have already solved this problem. Our client is from Romania and in the Romanian localization Internal consumption will be used. and I have to add item tarcking function to Internal consumption document. I added the the Item Tracking Lines form and it seems working properly but when posting fails. If you habe known the solution please share with. I will be very happy. Best wishes Sema Armagan
