I have installed Micrsoft daynimics NAV 2009 locally.
i can open the classic clients and classic clients with SQl server.
problem is that each time I try to open the RTC, it say Network currently is not available? any idea?
can any one help
Have u check your Nav Service is started or not?
usually classic clients are working!
its only the RTC its not working. I want to install the demo locally, usually it was installed in the computer and it was connected to a certain server. now I deinstalled it and I tried to install it locally.
its always gives me this error! but If i connect the computer to the company network it works.
finally after 2 days of searching, the error was here!!!
server address should be Local host!
the server address is taking automatically from your server of you have other version of NAV installed in your network. that why each time when I tried to install it locally I always had an error in RTC
