Network Alias
I wanted to find the Network Alias.
I have tried using xSession object, but it doesnt contain the info. i can find only the userid using xsession object. Also i have tried using SysUserInfo but yet not able to find the solution.
/Ashlesh
Try this
str machineName;
machineName = System.Environment::get_MachineName();
info(machineName);
Patrick
Hi, I actually dont required to get the Machine Name. I wanted to get the ‘Alias’ field from the ‘Users’ form. You can be reach there using “Administrator->Common Forms->Users”. I can easily get the ‘User ID’ from this form using ‘xSession’ class object, but i want to use ‘Alias’ instead of ‘User ID’.
print xUserInfo::find().networkAlias;
Hi Kranthi,
Done. It works perfectly as desired.
Thanks for your help.
