I have created a small .net class and build the project and following is the code. Actually this has nothing just a constructor that take a one string parameter ( I have tried this even without input parameter).
[code]using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace myDLLFile
public class Class1
public Class1(string myString)
[/code]
After that copied the .dll file to “C:\Program Files (x86)\Microsoft Dynamics NAV\71\RoleTailored Client\Add-ins” folder.
I have attached my DLL file and project file here.
www.sendspace.com/…/g/JwWjNW8iCcBryQ9k8BKA
And then i created a codeunit and create a new variable myDLL type DotNet and selected my DLL file from the Dynamics NAV tab.
It shows my class and everything was perfect to that point.
Then i wrote my small one line of code in the run() of the code unit,
myDLL := myDLL.Class1('t');
it compile perfectly.
But when i run the code unit it throws the following error
Cannot create an instance of the following .NET Framework object: assembly myDLLFile, Version=1.0.0.0, Culture=neutral,PublicKeyToken=acf764e249539b6a, type myDLLFIle.Class1
I have tried so many options. But still error remains same.
Please give a small help to resolve this small issue.
Thank You.
