.NET Marshalling not working?
Hello,
The follow code is has a basic string (str) datatype in AX that has a value which is supposed to be passed to the .NET String object. The marshaling is supposed to happen automatically, at least thats what I understand. Yet, what occurs is that the value of the string is “new” in every case. Any thoughts?
private void importFileData(str _fileName, FlatFileType _flatFileType, container _conDir)
int idx = 1;
str filePrefix;
FlatFileType flatFileType;
System.String fileName;
new InteropPermission(InteropKind::ClrInterop).assert();
while(conLen(_conDir) >= idx)
fileName = _fileName;
filePrefix = subStr(_fileName, 0, strLen(_fileName) - 3);
if (flatFileType == FlatFileType::ZIP && fileName.Contains(filePrefix))
pause;
idx++;
CodeAccessPermission::revertAssert();
