I suspect I know the answer to this one but I thought I would post anyway to see if anybody has any thoughts…
I want to use the funtionality available in a .NET class library in NAV by using the dotNet variable type but it is in a situation that needs to run as a service not an end user client.
We have always managed situations like this with Application Server which I understand does not run under NAV Server service tier so can’t utilise the dotNet variables.
In the days before NAS we used to leave a client running on the server, running a from with a timer trigger on but I don’t even think this is an option with RTC as I can’t see a timer property on the pages.
Any ideas??..
