Negative inventory
We would like to enable the negative inventory settings in the model group. However, is there any way to control use this settings. For example, only allow negative inventory for 10% etc.
There is no as such setup. If you check physical negative inventory, it will not validate for physical on hand inventory.
Pranav…
