Negative Inventory
Dear All,
We are facing a problem of occuring negative inventory .To solve this on which codeunit we have to write the code and how?
Regards
Sree Reshmi
You need to Write code on Codeunit 21 Item Jnl.-Check Line
As well as you can write code on Sales line Table -Quantity Field (Validate trigger) to check inventory during order punching.
This will help you.
You can simply set visible false on Yes button of form 342-Check Availability
Importantly you need to active Stock-out Warning on the Sales & Receivables Setup.
