Negative cost amount for receipts not allowed
ERROR:
Production order 00012727 > Calculating Production>Negative cost amount for receipts not allowed
Above error is coming while doing END of Production order.
Kindly help regarding meaning of this error and suggest method to solve this problem.
Thanks in Advance…
Hi Shivraj,
You need to check the prices of each item as well as bom whose prices might assigned as negative and look at BOM calculation as well.
Please look at the price calculation and look at your stock model group settings.
sarathy
If you put negative lines in a BOM where the cost is greater than the items used to produce it as a by-product AX will not like this.
Thank you !!
