Needs help in Refreshing FPPO
Hi ,
I have routing= ROUT200
I have also Production BOM = BOM200
Item 200 assigned to ROUT200 & BOM200
Going to FPPO Finished Planned Production Order
Enter Quantity for example 1 then trying to refresh forward or backward .
In both cases I am having this message , I don’t know if I make any error.
this message if i choose forward ?
ERROR WHEN CALCULATING FORWARD CALENDAR IS NOT AVAILABLE AFTER 28/9/06 FOR MACHINE CENTER M2
this message if i choose backward?
ERROR WHEN CALCULATING BACKWARD CALENDAR IS NOT AVAILABLE BEFORE 28/9/06 FOR MACHINE CENTER M2
Thank you
Hi Jouhayna
If you go to machine centre M2, go to planning and calendar, and then go to functions and calcualte, can you calculate the available capacity calendar entries that should allow you to plan the work.
Hi Steven ,
Thank y ou Boss …
It works well now .
Hi Steven ,
Sorry for duplicate posting .
If you can delete any one of them , I will be gratefull .
Thnaks again for your support .
