Needed an urgentr help
After running the help …
it will appear for example the field that you press the F1 at it.
But whwn you press at any hyperlink … it will give you this message … A Runtime Error has occured …do you wish to debug … Line 0 Error : Object doesn’t support the property or method …
what did we conclude … that after right click to click on view source … cann’t run javascript Alink.click … What it can be?? …
Thank you for any body can help …
