Hi AXperts,
I want to get well acquainted with SYSOPERATION FRAMEWORK in ax 2012 R3. But I am not getting much sufficient stuffs. request anyone of you to please send me an XPO if you have already done it before to
Thanks in advance !
Hi AXperts,
Thanks in advance !
And what should be in the .xpo? If you want examples of SysOperation controllers, for instance, you have plenty of them in the standard AX application.
If you want to understand the framework, first read the documentation and look at examples in AX. If you don’t understand something, use a search engine to try to find the answer and if it fails, ask a question here.
