need to restore security privilege to system version
hi all,
I modified a security a system security privilege by mistake. and I need to restore it to the system version. I found a restore in the AOT when right clicking the privilege but it didn’t work how to solve this issue
Thank you.
Right click on the object & Delete
Hassan,
When you make changes on any AOT object, restore will bring back the last saved version of the object. To restore it to the system version, you need to use delete option on the object. If you have made customizations on multiple layers, it will be required to delete the object from all the layers where it is customized, in order to get the system version.
