Need to process blocked items for returns
As part of a SKU rationalization process we are currently blocking item numbers that are no longer used. However from time to time we need to process return orders using these blocked item numbers.
Apart from blocking & unblocking the item number each time is there any work around?
John
Mostly the block consist of:
Item.TESTFIELD(Blocked,FALSE);
You have to modify this validationcode to accept returns (options in document type)
Thanks for the reply!
