how can i copy an exact window with calculations to another database? here’s how far i’ve got: 1.open the window that shows data. 2.do ‘tools’ ‘design’ and then see what i need for the sick database. thanks, Trint
I don’t understand your question, but transfering objects between two databases is handled by exporting the object (your form) and then importing it into the target database. Open Navision - show then main menu press Shft+f12 press Form find your form and mark it In the pull-down menu youl find “files” - “export” Here you can export your object (or multiple objects) to a file (*.fob or *.txt) Use *.fob Importing is as simple “files” - “import” and choose the file…
