Need help regarding SysLookupMultiSelectCtrl in X++
I am facing a problem, i am using SysLookupMultiSelectCtrl class to create a multiselt lookup grid.The lookup contains two columns Code, Description.But the problem is that i want to show the values of the 2nd column (Description) on selecting a record from the grid.but this does,'t happen, it will always show the first column value (Code) when ever i select a record from the grid. My requiremnt is that i want to show the description on selection in the control.
Hope you aomeone might have a solution regarding that.
This is the syntax of syslookupMultiSelectCtrl:
client server public static SysLookupMultiSelectCtrl constructWithQueryRun(
FormRun _frmRun,
FormStringControl _namesCtrl,
QueryRun _queryRun,
[boolean _isMandatory,
container _selectField])
Where ‘_selectField’ parameter is the one which will come in selection if you specify it. Here it is optional. Try to give and check.
