Hi, I try to connect to a Navision database through Java program, so I have to use JDBC/ODBC bridge method. First of all, I set up a ODBC DSN called RMI in data source. It has no problem because I can access database through MS Access. But when I use a small test program to do connection to the database, I received the error when program run DriverManager.getConnection() statement, the error is [Navision a/s][Navision Attain ODBC Driver]ISAM error. Can any one help me to solve this problem. Do I use the right driver? I attach my small program in case you need. import java.sql.; import java.util.; public class TestDB1 { public TestDB1() { } public static void main (String arg[]) { Connection conn = null; ResultSet rs = null; Statement stmt = null; try { String dbDriver = “sun.jdbc.odbc.JdbcOdbcDriver”; String dbUrl = “jdbcdbc:RMI”; String dbUser = “”; String dbPass = “”; Class.forName(dbDriver).newInstance(); conn = DriverManager.getConnection(dbUrl, dbUser, dbPass); String sSQL = "Select * from item "; stmt = conn.createStatement(); // execute the database query rs = stmt.executeQuery(sSQL); while (rs.next()) { String commentDesc = rs.getString(“description”); System.out.println("CommentDesc is "+commentDesc); } rs.close(); stmt.close(); conn.close(); } catch(Exception e) { System.out.println(e.getMessage()); } } }
