Need Help for Rounding Entry in Value Entry Table
Hi, As we all know that this is an issue in 3.60 version, could anyone please till me that how can i rectify/reverse these entries. This is creating mess in our clients database and he need to submit the accounts asap. Regards
Hi, Have you applied all the released hotfixes?
Hi Rajesh, TO apply all the hotfixes needs merging the customisation which could take a lot of time for testing which i could not give. Regards
One more thing that hotfix will not post new rounding entries in the system, but what about the entries which have already been posted in the system?
quote:
If you can’t do this, then you are in the wrong business??? As far as fixing the existing issues, There is a document from MBS called Costing Error Detection and Data Correction. This will give you an idea of the steps required to fix the issue(s).
We also have a lot of problems with the item costing. We have applied all the released hotfixes (3.60), but still there will remain several wrong postings. Where can I find the MBS document “Costing Error Detection and Data Correction” ?
Hi chris, Can you mail me the document “Costing Error Detection and Data Correction”. my mail ID is amitschandra@yahoo.com Cheers Amit
Can you give me this document too? We have also Problems with this topic. → stefan.bacher@blum.com thanks
You should be able to get it from your NTR.
Hi Chris, Could u please sent the document otherwise we could loose our customer… My Id is “im_arora@rediffmail.com” Thanx
