It 's occurs when running Adjusted Cost-Item Entries. I 've went through the code and found that the decimal variables and fields were rounded. Why should this happen?[B)] [?] I used to get the Overflow in text variable but never with decimal. Thanks in advance. [8D]
A Decimal can be -999.999.999.999.999,99 to 999.999.999.999.999,99 Use the debugger without breakpoints to see where the error is.
There have been a number of issues with the Adjust Cost-Item Entries report since 3.60 onwards. You problem appears to belong to this group. It is mention specifically in the document Guidelines for Loops in Adjust Cost Batch Job.doc
I forgot to report the link to this document. http://www.mibuso.com/dlinfo.asp?FileID=364
