Need a Codeunit for Barcode printing UPC-A
Please provide me the Codeunit for printing Barcode in report for UPC-A Type,Really it is urgent
Please don’t post that it’s really urgent - no one will help you then. If it’s that urgent make a MS supprt ticket.
Did you even try GOOGLE? Or search the forum or make any effort other than asking a question?
I have searched everything and trying to do this since last 3 days.Downloaded so many objects from mibuso, tried all help and now i have to deliver this. plz dnt mind if i hv put this urgent.
What didn’t work from the downloads? Did you try a Font? The Barcode Generator? Or are you fixated on using a CU only?
Did you read my reply on your other post on this subject about UPC-A being outdated as compared to the same barcode as EAN13?
http://www.barcodeisland.com/ean13.phtml
If you really want UPC-A
http://lmgtfy.com/?q=upc-a+font
thnkx for ur reply i have EAN 13 which uses Codeunit to print the barcode.the items which i have to scan has UPC barcode and when i sell those items the bar code should printed with the invoice copy.If EAN 13 and UPC has same identical symbol then it is fine if they have some difference then i will have problem.
They are the same symbology but upc-a is 12 digits EAN is 13
Best way to tell - download some fonts & get cracking!
http://lmgtfy.com/?q=ean13+font
I am new to the Barcode in Navision but how to proceed with it. I want to design a Report which converts a Particular No. to UPC-A Barcode.
You search the forum for Barcode? Really? It’s been discussed 1000 times.
Did you try installing a barcode font & changing the font of the field to that barcode name?
I believe for UPC-A you also need to throw some *'s around it.
You said you downloaded some stuff from mibuso. What did’t work for you?
I am searching for the UPC-A font but i have not got one but suppose if i download this font from some where and then i need to print the Item no. in barcode symbol and then after changing the font property of the box to download font it will work right. I am searching for the fonts can you explain this little more it would be a great help.Now i think everything is getting clear for me
you say “Particular No. to UPC-A Barcode.”
Is this particular # a 11,12,13 digit #? or are you looking to just make a(ny) number scannable?
That’s another aspect you need to look at. I’m no barcode expert but it’s called UPC-A for a reason.
It you are trying to turn text , digits or some combination into a barcode I would suggest Code128 then.
If whomever you are doing this for says they can only scan UPC-A then they need fix their barcode scanners.
Most if not all scanners can scan multiple barcode types, you just need the manual to “teach it”.
Example Here:
http://www.pos-x.com/downloads/Xi1000_programming_manual.pdf
I really Appreciate your reply Sir, my Requirement is when i purchase the Item and it has barcode in it and i want to scan the Barcode so that i can put that Number, which i had scanned in Item Tracking Lines.After this i will make a sale and now if i print the Invoice for sale then i just need to Convert those serial No.(No. in Item Tracking Lines) to Barcode and attach the list of barcodes to the invoice.
That sounds all good but why are you stuck on UPC-A?
Just use 3of9.
there’s nothing really more to say to this post.
You have been given everything you need to accomplish this task as well as 1000 other barcode posts in this forum alone.
Good luck.
buddy try these bar code printings code 39 and code 128… this is accepted in most places
http://www.mibuso.com/dlinfo.asp?FileID=1456
http://www.mibuso.com/dlinfo.asp?FileID=1192
you can just donwload and use them…
Anil.
i have several years’ experience in generating barcode, i think some turioals and articles might be helpful. you can googleUPC-A Barcode , and some articles can be available. i can give you some if you need .
this is the turoial of generating UPC-A Barcode , you can ,make it as reference and the tool if free for 30 days.
this is the barcode generator in c# and other formats, i think it might also be helpful
good luck.
i think it’s almost the same as do in other formats. i have several years’ experience in creating barcode , so i can give you some advices.
this is the tutorial of generating UPC-A barcode from which you can learn a lot
this is the barcode generator in c# and some other formats. it can be freely used for 30 days.
if you are still confused , you can go to codeproject to find some instructive articles about the issue, good luck!
Just make full use of Google. Put “UPC-A barcode generator” in Google, you can find a lot of tools like this. I am not sure in which report would you like to create barcode in, create UPC-A in Crystal Report? or create UPC-A in RDLC reports? Just put this on Google.
By the way, I suggest you use a barcode tool which supports to resize the barcode. So you can change the size of the barcode and create any ideal size of barcode.
EAN-13 is a superset of UPC-A. This means that any software or hardware capable of reading an EAN-13 symbol will automatically be able to read an UPC-A symbol. you will need a EAN-13 reader and a UPC-A generator c#. you can googl out a lot. so you can read and print out easily.
