This is the newest version of these powerful tool to analyse your cal/source code. Why?
- Highspeed 4 Sec compared to 120 sec with DevelopToolkit. - Searchfunction with regular expressions, … This function is similar to DevelopToolkit - analyse unused sum index field - analyse unused variables - analyse unused functions - analyse unused table fields - analyse Table reference problems - analyse Field reference problems - analyse only once used variables - analyse local = global variables - analyse double IDs (after merge is very useful) - split objects to separate files - search all fields, all tables in a specific range of numbers. - Modul - simply Analyse your license - what is free, what is free and the linked object doesn´t exist. - watch and protocol the changes to a navision server - no installation New in Version 4.3 - Search a in specific range of Numbers. e.g. all objects and TABLEFIELDS in the range 50000…60000. You´ll like this functions to structure your code in moduls etc. - Search PageName-Problems. This error is not detected by navision compiler - so especially in applications including more than one language this is indispensable. - OnlineAnalyse is now able to export the results in a file, that can be read by ccaps generator. You can easily license hundred´s of objects in a few seconds. - A new view is integrated: CompareView: Your´re now able to compare two databases and get the different objects listed. A further function can mark these objects in both databases. So you´ll be able to mark the objects in the objectdesigners of both databases and easily export, save the concerning objects. We tried to use Development Toolkit, but there are a lot of problems with it and so a lot of external partners and a lot of our own developers use this tool and are very sophisticated with it. Try it! if you like to test these get the free demoversion at www.mibuso.com or direct from Matthias.Sebald@astonIT.com
