Navison 5 smtp
I have just upgraded from Navison 4 to 5.
I want to start using the smtp function in Nav 5
How do I stop Navison using IMAP and Outlook and use SMTP instead
You need to use codeuint 400 — SMTP Mail
Sorry abit new to this, can you tell me how to do this
Test this
open new form and 1 button
create variable … datatype = codeunit … subtype = 400
on push
your variable.CreateMessage(SenderName,SenderAddress,Recipients,Subject,Body,True)
your variable.send
before send you must go to form 409 to define your smpt mail setup
Where do I find the form 409 to setup the smtp mail
Go to Administation >>> IT Administation >>> General setup >>> SMTP Mail Setup
I have put info in there.
SMTP Server : mymailserver
Authentication : NTLM
How Navison know to use SMTP and not IMAPI
Codeunit 400
this codeunit make NAV use SMTP
Authentication : Basic
User ID : your id
Password : your password
Will Navison pick up UserID and password?
As I have 300 users using Navsion
No you must define user ID and password
Does this mean every user has to login to Navison and setup there smtp connection
This there anyway of importing these settings
No any user can send mail with this setup
user id and password to access on SMTP server and you define the sender name and sender adderss in code
Sorry about this can I just clarify.
If I goto object designer then to codeunit it shows 409
I have setup 409 smtp details.
So will Navison now use smtp and not IMAP
You mean form 409
Yes
I am getting error “email service failure”, if I open Outlook it works
Check if your fire wall or ISP are not blocking the SMTP server.
Especially when using McAfee VirusScan Enterprise, the system will block all outgoing SMTP traffic except for programs listed.
