I have an issue trying to integrate Navision with a webservice.
I can read in the XML fine via soap and can load this into an XMLDom object. My problem is caused by the format of the data.
The data in the XML does not map onto any navision fields and therefore I need to handle each tag individually to decide what I need to do with the information [:’(]
The xml returned will be in this format:
field1value
field27value
etc.
The list of fields and name of fields will vary from record to record and new ones will be added over time that will need to be handled and this is oiut of mu control. (I will be looking up the field/tag name in a separate table to handle this!).
So what I need to be able to do is take each ‘record’ tab in turn and then read the list of field/tag names and values in order whatever they may be.
I have done something similar using ‘getelementsbytagname’ in C# but can’t seem to get this working in Navision.
Any ideas or pointers in the right direction would be hugely appreciated. I’m sure there is an easy way of doing this but I think my brain has fried in the heat [;)]
What version are you using? 4.0 has xml ports that you can use. It has property called MinOccurs that you can set to zero for all the elements.
If not then I would create a table where you can define the field tags to navision fieldNo.
While decoding the xml document you’ll loop through the records and search for them in the xml document. As new xml tags are added, you only add them to the table. You have to use fieldreference and record reference to be able to do this.
I would try to generate a new table with mappings for record identifiers and field tags.
Once you receive the XML file , you just search for the identifier in your table and know what table it relates to.
Then you loop through all fields in that table and try a GetElementByName (I cannot exactly remember if that was the name)
Then you should be able to find all fields you are interested in.
To extend your functionality you just need to add additional TAGs to your definition table.
I can’t use easily use XML ports as this would need resigning each time a field was added - and I think this is going to happen a lot!
I was already leaning in the direction of Thomas’ suggestion and will go that route. Now all I have to remember is all the quirky things about using XMLDom in Navision so I can code this. [;)]
