Navision workflow solution?
Are you of any workflow tools that integrate with navision e.g filenet e-process ?
Hi, The Indian version of Navision has built in workflow functionality. This basically caters to workflow authorizations on Purchase and Sales Document only.Follows an authorization e=sequence based on the hierarchy ( Hierarchy also is based on order amounts or no order amounts.) Regards, DD
Dear Dharmendra thanks for the info. Is this available as a an add-on on Navision ? Thanks
Hi, This is not an add-on. Just offered as an additional functionality. The alerts are only upon logging in by the respective user. and /or e-mail is generated as a part of this.( Provided you have MS-Exchange Integration Granule.) Regards, DD
hi ! Is this functionality available through microsoft ? Thanks tryfonas
