Navision vs. Notes
Hello, have anyone a you experiance in data Exchange between Navision and Notes (Navision and Gedys) ------------ Best regards Alejandro Schubert schubert@dolphinct.de
We often pull data from Navision into our Notes system using C/ODBC.
We pull data from Navision into our Notes system using C/ODBC daily. The only time you might encounter a problem is when you are trying to run two different versions of C/ODBC.
Take a look at KLOSTER IMPORT’s website, you can find it under Navision links Best regards Preben
