how do i get commands to be triggered by a button i design in navision to export directly into sql server 2000? thanks, trint[:o)]
This is simple, you just need to create a view of the SQL table, and then populate it like you wuld any other Navision table. Remember that if the view is not common to all tables, then you will ahve to create the name of the table including the company name. If you can, do it as common to all companies and make life easier.
