Hi, all.
Where I can find documentation with Navision Start-up Parameters list?
Hi, all.
The standard pdf installation guide has a full list of startup parameters.
Ones I use most are:
Database= , company= ,
and id= (zup file location).
quote:
Originally posted by Adam Seaton
The standard pdf installation guide has a full list of startup parameters. Ones I use most are Database= , company= , and id= (zup file location).
I am sorry. I can’t find installation guide on install cd. I found in \doc\w1 dir only these files: Directory of H:\Z_Navision\Attain 3.60\Doc\W1 02.01.2003 13:47 <DIR> . 02.01.2003 13:47 <DIR> .. 02.10.2002 13:43 <DIR> Compnotes 02.01.2003 13:47 34 dir.txt 11.06.2002 13:55 114ÿ688 E-Mail Logging for MS Exchange white paper.v1.doc 04.07.2001 10:54 524ÿ800 NAGUIGuide.exe 06.06.2002 16:07 4ÿ251ÿ286 w1w1adg.pdf 06.06.2002 16:09 395ÿ169 w1w1atas.pdf 06.06.2002 16:08 950ÿ829 w1w1cfront.pdf 06.06.2002 16:08 925ÿ834 w1w1codbc.pdf 17.07.2002 09:17 1ÿ261ÿ946 w1w1InstADCS.pdf 06.06.2002 16:09 537ÿ951 w1w1instEcomm.pdf 21.05.2002 14:18 1ÿ995ÿ239 w1w1int.pdf 25.07.2002 12:13 1ÿ672ÿ677 w1w1ism.pdf 25.07.2002 12:13 1ÿ319ÿ904 w1w1isql.pdf 03.12.2001 11:40 504ÿ119 w1w1term.pdf 21.05.2002 14:19 725ÿ948 w1w1upig.pdf 14 File(s) 15ÿ180ÿ424 bytes
Hello, the installation guide you are looking for is the file w1w1ism.pdf (ism = installation and system management)… [;)] Saludos Nils
quote:
Thanks. I have been confused, because title of this doc is “Installation & System Management:Navision Attain Database Server”. I sought doc for client, not for server [8)]
