Is there any possibility to run Navision Scheduler as NT service? The main problem is to start it automatically on server reboot or Navision server restart. [?] P.S. We still working on 3.10
Have you tried using windows scripting host, to open navision and send keystrokes to start you navision scheduler? Then you can put the script file in the startup of the server. Regards, Gus
Interesting idea [:D] So, native Navision solution does not exists? Will this work if nobody logged in server? And how in this case determine, that scheduler is stoped and restart it?
No native solution, I think. In case you don’t log on to the server, you should use windows’ own scheduler to execute you windows script file. Remember to write you script, so that you detect whether a copy of Navision is already open and just re-use it. In the script try and start the scheduler, if it fails (because it is already running) then no problem. Cheers, Gus
