Hi, I am relatively new to Navision. I am not sure exactly how easy it is to create your own reports or change existing reports using the object designer tool. If anybody has got any good suggestions where I can get some useful info on how to do this I would be very grateful. I was looking for the ‘Application Designer’s Guide’, as it says in the help this will tell me how to use the object designer. I have managed to create new reports based on 1 table, but i am struggling to join information between 2 tables. For example, Customer details relating to their invoice details. Thanks, Craig
The best ways to learn how it works are: * Attend a programmers course * Look at the available reports and try to understand how they work.
And if you run into a problem, try searching on this site… There are a lot of posts about report designing. Success!
Yes, and I’m not getting tired to link you to David’s “Learning Dynamics NAV - Introduction” topic: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=16258 check this topic out and follow it. It will definitely take you some time, but without knowledge of the table structure you will not really achieve what you need.
Originally posted by tb@softsys.at - 2006 Jan 30 : 05:05:18
Thanks for this, sorry for sounding like the same old song…
