Navision on Citrix Server
We had Navision client available on a Citrix Server running no problem until recently. It now comes up with the error “The date is not valid”. ( Other applications work fine). I can reinstall the client and it works ok for that day but the following day it’s back to the same error. Anyone any suggestions?
Topic moved from Developer to Technical forum. Best regards, Erik P. Ernst, webmaster
Check the configuration of local settings on both server and user profiles. I remember having that problem when having a server with the british/american (mm/dd/yy) date configuration and having clients using the standard european way (dd/mm/yy). The firsts days of the month the error was not detected as the dates were existant ones (wrong month/day but existant ones), but when using other dates (like 25/01/00) it was when having errors… (if 25 is the day and 01 is the month is ok… but there is no month 25)… Regards, Alfonso Pertierra (Spain)apertierra@teleline.es
