Is there anyone out here who wrote a tool (Freeware?[:D]) which basically print out the list of objects that can be EXECUTED and that also those that can be (EXECUTED) AND (WHICH ARE FREE/AVAILABLE OBJECTS) If you got such a cool tool, would you be able to post it in the Download section of this web site.
In the 3.60 (NA), there is a report 10313 which I think is what you are looking for. I could probably send you that object if it is not included in W1.
Hi Tarek, u can create a form with table “License Permission” and run it.It will give u the list of objects and permissions for the license u r currently using.Hope this helps u…[:)] regards, Lakshmi.
Chris : I do not have a 3.60 CD So I would appreciate if you could send this report to tarek_demiati@ureach.com Cheers, Tarek
