Navision Integration
Hi Experts
I have a two database in MS Sql server 2000,one which is using Microsoft Dynamics NAV 4.0 as front end and another one database using Visual Basic as a front end,I need to insert and retrive data from VB to NAV,both databases are in SQL Server 2000 is’t possible to do so…Give your valueble sugesstions experts
Thanks in Advance
Regards
Thiya
Yes, it is possible. The approach depends on the details of what you want to do. From which client (NAV or VB) do you need to access/update data in which database?
Hi Babrown
From VB to NAV as well NAV to VB.These two has different database in SQL server 2000.Fox ex NAV_DB for NAV and VB_DB for VB.If any transaction happens in VB_DB it ll affect into NAV_DB,same like if any transaction happens it should affect into VB_DB.Here these two has a database in SQL server 2000.How to INTEGRATE these databases.
Thanks in Advance
Regards
Thiya
That’s not a lot of information.
