Is it possible to convert NF2.1 database to Sql Server. I am not sure about this. thnx
Yes - you back up the database and restore it into a SQL version (after performing some migration checks to check your data validity for SQL Server). You cannot use Financials 2.1 if thats what you mean - you need at least 2.5 to get the SQL version; but I recommend using 3.7 executables.
