Navision Documentation
Hi all, I downloaded a lot of documents for Navision but I haven’t found these ones : - Is there any User Guide that briefly describes the ERP, its main functionalities (navigation, lookup, drill-down, flow filters…), the GUI (menu buttons, toolbar…). - Is there any template that contains the core elements an Analysis report for a Navision Implementation should contain. - Is there any document for Navision that explains a typical migration process. Thank you for your help.
Hi Mani, U can go through the following documents: w1w1adg.pdf,w1w1ism.pdf,w1w1cal.pdf,08W1.PDF,09W1.PDF Hope these will help u. Himadri
