Hi, does NDTK v. 2 SP1 work with localised 4.00 databases? I’m trying to import from client an Italian 4.00 database, but I’m getting the following error: “The Language of the file to import does not match the language of the .stx file. Import stopped!” [B)] What might it be the problem? It does work with Italian databases of earlier versions. [:(!] Anna
Hi Anna, go to register “Keywoeds” in the Import window an change the fields manually as they appear in the first lines of the file you want to import OBJECT-PROPERTIES { Date=02.11.05; Time=15:23:10; Modified=Ja; Version List=UPD 4.00, EK;
br Josef Metz
Originally posted by jm - 2005 Nov 03 : 17:31:11
Thank you, Josef! It worked. [:D] They were set for Italian, but in version 4.00 keywords aren’t translated. Anna
