I get the following error message when i take navision backup ‘There is an integer that is too large 2,175,841,286’. The message comes as soon as i start the backup and am unable to find the source of this error or which table gives me this error.
When you start the backup, you should see the object-name in th backup-window?
Try the following: On File->Database->Test and choose the Normal test… it will probably give you where the error is… so you can then have more chances of solving the problem. Alfonso Pertierra (Spain)apertierra@teleline.es
Abdullah, One of my customers encountered that issue. Do the database test and see which table(s) it stops on. Then try to export it to text (simple dataport with all fields in it). In my case, the error was caused by a boolean field that had this value, instead of Yes or No. If that is the case, you could try to edit the fields. Alex
Moved from “Open Subject” to “Attain Technical Forum”
