Hi all, Im trying an installation of attain 3.10.A on a server2003 box, the installation gets going, and just after the MDAC2.60 part of the installation, you see a roll-back screen, and then a screen saying: “The wizard was interrupted before the installation of Navision Attain 3.10.A was complete. You system has not been modified. To complete installation at another time, you must run setup again” What could be the problem ? Server compnent running fine. Thanks DANIEL
Hi, I guess you are trying to install Navision Client. To make it working Navision on that PC you can take anoother approach. Just copy the client directry from CD and change the readonly directry attribute. To access the Navision you can create the shortcut on Desktop or double click on database in that directory.
