Navision / Attain upgrades
Hi All, according to my understanding you can simply copy & paste fields & functions from a lower Attain version (for example 3.01) to a higher Attain version (for example 3.60) but you cannot do so if you are upgrading from any Navision version to any Attain version. The reason is a chnage in the C/Side and properties of fields & functions differ in the Attain version. Does any one know more about Navision to Attain or Attain 3.01 to Attain 3.60 upgrades.
Hi Ikram, Navision Attain 3.6 and 3.7 version having the same C/AL code and Functions as Navision 3.01 or 3.1 was having, except some more Function and command are there in 3.6 and 3.7 version.
You can copy & paste fields and functions to later versions (I think doesn’t care from how old) but can’t copy & paste to earlier. You can Financials → Attain → Navision. You can’t Navision or Attain → Financials. Sometimes it may work however errors can occur.
Hi Ikram, There’s copy & paste problem with Sections/Control in Reports from earlier versions to Attain b’cos Attain assigns unique ID for Labels/Controls generated in Attain for supporting Multilingual features. But I haven’t seen any problem in copying/pasting fields/functions.
Convert copy of 3.01 data base file to 3.6 version and you will able paste/copy any data.
