Navision Attain 3.60 on SQL Server 2008 R2 ?
Hi everybody,
Since we migrate our Navision 3.10 from Native DB to SQL Server 2008 R2 successfully using 4.0 SP3 client software, I cannot find any confirmation the same is possible with Navision Attain 3.60 DB.
It seems that only the C/Side client is required but I wish to be sure about it.
Does someone can confirm my guess ?
Thank you for your help
Franck
Hi Franck,
If you want to use SQL Server 2008 R2, then I would surely recommend that you do a technical upgrade from Navison Attain 3.60 to Navision 4.0 SP3 first. Especially because this client version is the only of the classics Navision versions, which can run on the newer versions of Windows.
But remember it depends on your company’s Navision license. If you don’t already have the SQL Server “granule” in your 3.6 license, then even if your license allows you run 4.0, you cannot get it, unless your company still have an active upgrade subscription.
So check that first.
