Navision Application Server
How a Navision application server can be called from the navision application client?
It would be greate help if some one could help me with sample codes.
Thank You
The Navision Application Server (NAS) does not get called from the Navision Client. NAS is a client without a UI.
You can create a form with Codeunit 1 as a global.
Then put a button on the form and put some code in the OnPush-trigger calling the NASHandler() with the desired parameter. F.i. when you want to run the Exchange emaillogging from the client for debugging purposes the code would be
NAS.NASHandler(‘MAILLOG’);
NAS being the global variable.
