Navision Application Server
How can I test to see if my application server set-up is correct? I have putt all the info in and the service is running but the codeunit I have created for testing does not appear to be doing anything. Any suggestions most welcome Cheers in advance
Did you modify codeunit 1? Have your codeunit writing a line to an external file, or something else to have an input if the codeunit is started.
Modify cdu 1 - NAS Handler Function. Simply put “MESSAGE(‘NAS TEST …’);” Start the NAS in services window. Check event log for information message “NAS TEST …” will be here if your NAS is working properly!
