I am finding analysis by dimensions a little “2 dimensional”. I would like to perform an analysis by G/L code by date showing all available dimension codes in a particular category rather than just one (which the filter allows you to do). If I were able to get Navision to produce this I could download into an Excel spreadsheet and carry out pivot reports on it. Thank you.
Hi Alan Analysis by Dimensions with the rows as GL and the columns as the Dimension would seemingly give you exactly what you want. Then use the Export to Excel funciton.
