Hello,
Need two columns 1 to represent Year To Date Last Year and heres the tricky bit a column that represents the Date Filter Last Year. So for example I could have a date range in the date filter for 1 month and would expect the Date Filter Last Year to represent this balance last year for the month specified.
Regards
Andrew[H]
Hi Andrew,
I think you can do that by using the “Comparison Date Formula”-field in the column-setup.
If you type -1Y here, then that column should show values using the same dateformula, only a moved a year back, as defined on the report request.
So if you set your datefilter to Q1-2009, then the column should use datefilter as Q1-2008.
If this is not the solution, then i don’t think it can be achieved using account schedule.
This IS the solution.
Comparison Date Formula is used just for this purpose, but setting Column Layouts is rather tricky, I just wrote about it in http://dynamicsuser.net/forums/t/26745.aspx - take a look there too, Andrew, and search for “Account Schedule” - there have been many threads here in forum with examples…
