When i right click in text boxes in NAVISION 4 SP3 on server 2008 64 bit(I have use the update roll-up to enable Nav 4.0 SP3 with Vista.) i’ve got the message Microsoft Business Solutions has stopped work.
Well, I’m afraid the NAV version you are using - Build 24080 (SP3 Update 1) - is a quity “buggy” one, and NOT able to run on Win/SQL Server 2008 - you need at least NAV 4.0 SP3 Update 6 Build 25143.
But honestly, also this build is somewhat “insufficient”, actually you need Update 6.9 (Build 26565) or higher. The most recent version is Update 6.18 Build 28541.
did you look at Waldo’s blog, the steps to get the KB are quite clear. If you are not a partner, then contact your partner to do this. If you are a partner, then you should already know how to do this.
Please, if any of the replies to your post solved your problem, then please click on the “Verify solution” next to that post. This way we can see that your post is closed and you got the help you needed. If you found another solution to your problem, then please, out of courtisy to the members who helped you here, post the solution here.
