Navision 4 reports
Hi all! Please can anypne tell me if in Nav4 , those reports ( or similar reports with little customisation) can be found: - Expediting report : this report identifies articles that should have been received. Expediting date is entered in order to query on that. The listing should present: PO, Vendor, Order Date, Item Number, Item Description, Quantity to receive, Job, Task, Promised Date. - Low stock report : This report gives list of parts that are at the min or lower (inclusive). - Min/Max Analysis report : On this report, the System will propose a min/max on items. - Back order report: Give list of parts that are back order - Requisition Items Awaiting Transfer Order: This report will list parts that must be transferred to another location Thank you very much.
Nearest I believe is Purchase - Order Processing - Reports - Inventory Purchase Orders
I do not believe technically a standard Navision report exists for this. However have a look at Purchase - Order Processing - Reports - Inventory Reorders, shows inventory, ROL and reorder quantity. Technically though your minimum is different to your reorder level.
I do not believe a standard Navision report exists for this.
Presuming this is sales backorders Sales & Marketing - Inventory & Pricing - Reports - Inventory Sales Backorder.
Assuming you have actioned the requisition worksheet and created the transfers then Purchase - Planning - Reports - Inventory Inbound Transfer.
Thank you very much Steven.
