Navision 4.00 menu suite
Hello, Is it possible somehow know by which menu item from menu suite the form was called? (smth like LAST_MENU_GUID, since each menu item has its own GUID). The problem is, that I have one form, which always was called (from main menu in Navision 3.60) with SETTABLEVIEW before, and in Navision 4.00 it is impossible to do some code on menu item click. So, how should I set filters before the opening the form? Any ideas for the solution of problem? Except that creating lots of form copies (in my case there should be ~20 copies).
Sorry, I found the same topic: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=13198&SearchTerms=menu – Regards, Justas
