Hi! I Navision 3.70 a cluster-aware application? or clusterable but not cluster aware? I want to install it on an windows 2003 server with nlb (load balancing) cluster. Has anyone experience with something like that? Thanks
It is not cluster-aware. But installing on it cause no problem. But you cannot load-balance SQL or CSide anyway. So, the advantage is really not there… To properly create a truly scalable Navision, it will involve creating a Federated-SQL Navision DB, which, is close to impossible. SQL Server 2000 Enterprise Ed. at this moment in time do not support load-balancing… But it does allow Federated DB. (Google Federated DB if you don’t know what it is). I’d wait for Yukon personally.
